SybcBlaster v CSY-2100
Discussion in 'Cables & Switches' started by lloydde, Jan 3, 2004.
  1. lloydde
    lloydde
    Nov 10, 2003
    10
    I am connecting my Sony DVD player, with only a single Scart output, to a Panasonic TH-37PWD6UY Plasma tv. The Panny accepts Component Video. I have narrowed the choice of RGB Scart to Component converters down to the Keene SyncBlaster Scart to Component cable or the CSY-2100 Scart to Component converter from Scancom. Which is best? I am confused as to how a relatively simple cable (Syncblaster) can perform the same function as a powered conversion box (Scancom). Any views would be appreciated.
  2. Jason S
    Jason S
    Have a look here before you make a decision
    http://www.js-technology.com/
    The convertors available here are considered by most of us on the forum to be the very best you can buy.
    I had the CSY-2100 Scart to Component unit, and replaced it within 24 hours with
    http://www.js-technology.com/rgb-yuv/index.htm
    It's a little more expensive, but you've paid several thousand for a new display, you may as well feed it with steak instead of hamburgers ;)
    Also, I don't believe that Keene do a cable to convert RGB to Component, but they supply a breakout cable to produce RGBHV (5 RCA's) So this may not be suitable for you anyway.
  3. lloydde
    lloydde
    Nov 10, 2003
    10
    Thanks for that.
    The input on my Plasma, called Component/RGB, comprises 5 connectors. VB, HD, Pa/Ca/R, PaCa/B and YG. (may have got some of the letters wrong 'cos they are written very small). From the manual it shows a component connection from a DVD using just the last three. Pa/Ca/R, PaCa/B and YG. Then for connecting from a RGB (R,G,B,HD,VD) signal source it shows all five connections being used.
    I am generally confused but when connecting a basic Sony DVD player which has a scart output and according to the manual outputs RGB, do I just use the three connectors as per your excellent JS-Technology suggestion or use say a Keene cable which starts as a Scart and ends up with five component connections?
    Any further words of wisdom would be much appreciated.
  4. Jason S
    Jason S
    I think the RGB connection is potentially the easiest for you initially, as you would simply need the Keene Syncblaster cable
    SCART TO 5 BNC RGB Hsync & Vsync (2.0M) SBB42 (or longer if needed)
    Personally I've never gone down this route as I've equipment which generates component signals (DVD / XBox) and so opted for the JS Tech convertor for my NTL Cable to keep switching simple. But I see no reason why it wouldn't suit you to start with, as long as your display is compatible with the horizontal line frequency of 15Khz (in the manual hopefully)
    Here's a thread about the same cable connecting to a projector.
    http://www.avforums.com/frame.html?...did=36048&highlight=SCART+BNC+RGB+Hsync+Vsync[/url]
    Also, Keene are a pretty good company, and if you try the lead and it doesn't work for you, you should have no problems returning it (as long as it's a standard length)
