Quantcast
Sy router - new D-LINK DSL-2640S?
Pugs1
Just got this router. Anyone know how to get the user name and password out yet for it so I can use my own router?
beerhunter
Is that what Sky are sending out now?
It is a perfectly good router unless you want 802.11n so unless that is the case, why not use it?
Pugs1
It is what Sky are distributing now. It appears to be ok but it's a bit limited (only two pieces of wired equipment can be connected and limited to 54mpbs wireless, no N) and I'd like to use my own router instead. Strangely, on the back are two RJ sockets that are marked green and blue and are 'earmarked' for future Sky services.
brynhh
Yeah, I got the same one the other day, and the connection just got changed over about 10 mins ago. Seems perfectly fine to me, can change the ssid, password, encryption mode, don't really need anything else from a router.
My only grumble with it, is it doesn't allow seperate WPA or WPA2, you can only used mixed mode, which seems a bit daft, hopefully they'll update the firmware.
I haven't tried all 4 ethernet ports because I use homeplugs, but if indeed only 2 are active, why not just use a hub? I got one from ebuyer for less than 20 quid.
beerhunter
I'd just ignore those labels an use those ports. It is difficult to believe that Sky have disabled them. At home, I am currently using 'crippled' DSL-2640R (ex-TalkTalk) as four port Ethernet switch. .
Cliveaff
Have a look at this site "skyuser.co.uk" they are a independent site, not belonging to sky.
I got my username and password for my sagam router, with help from them.
I hope this helps.
Jammie dodger
I read that one of the previous Sky routers also had two "reserved" colour coded ports, which are fully functional Ethernet ports.
Jammie dodger
I expect Sky will have tried to make it even harder to obtain the authentication details, than the previous two routers.
Out of curiosity, does the router respond if you attempt to telnet into it?
Pugs1
Yes, can confirm the ports work ok.
The username & password is for your sky broadband login account details. I cant find anything on extracting these as of yet:thumbsdow
Rafe
I got my details using SkyUser.co.uk when my original 'Sky supplied' Netgear 834GT died. However, that was quite a while ago.
Here is the thread:
Ive done it! Flashed router and got my sky password!
I doubt this will work for your new style router though?
Pugs1
That wont work for this router.:(
circuitmonkey
Apologies, I didn't actually have the patience to read the entire thread, so this may already have been found but here goes...
username: admin
password: sky
enjoy :clap:
gerimo
Yes - looks like Sky have done some more work on protecting this new router. Seems they have changed the way the user ids (based on MAC) and/or password generator works again. Previous hacks for the Netgear and Sagem Sky routers no longer work!
Also, they seem to have successfully disabled telnet access into busybox to allow remote login. Telnet is there but it terminates the session immediately - must be a coded login protecting it.
As ever Sky won't provide support. Someone has logged in as root but didn't say how they did it. Will do more research until we find a way.
Sorry - forgot to mention that admin / sky is only the admin user on the setup. They have hidden and protected the real user id and password being used to log in to CHAPS within the firmware. You can't see it in the setup information. They must be using a remote setup utility to configure these routers before sending them out. Just need to figure a way in.
Similar threads
Trending threads
