switching from skydigital to telewest digital
Discussion in 'Cable TV & Virgin Media TV' started by Joe Pineapples, Sep 14, 2004.
  1. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,473
    Doncaster
    +1,191
    Contemplating changing from my skydigital package (£19.50 pm), to telewest digital bundle (£30 pm - phone line, 256k 'always-on' connection, 35 channels). it definetely makes sense from a financial point of view, taking into account my current dial-up ISP cost, and the number of channels i bother watching on sky. Two questions though about telewest digital broadcasts.....
    1. Is everything that skydigital broadcast in widescreen, given the same treatment with cable?
    2. Is there an equivalent 'press backup' workaround for cable broadcasts, to get rid of the red dot?.
    cheers
    Dean
  2. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,473
    Doncaster
    +1,191
    forgot one more question (just incase anyone can answer)
    3. Is the picture quality about the same in general?
  3. Seven3840
    Seven3840
    Jun 30, 2004
    127
    +8
    Not sure how helpful this is but you can remove the red dot on telewest by pressing the blue button. Not sure on wether the pq is better or worse as ive never had sky but telewest do broadcast alot of films in widescreen, not sure if they match all that sky do, but a sufficient amount are.
    Steve
