Forgive me if this is a stupid question, I'm a bit new to all this.
I've just bought my first LCD TV. I ended up going for a Acer AT4220, I know it's a basic model indeed but the reviews seemed canny enough for a budget set, so I went for it.
When I set it up I was immediately disappointed with the picture. I followed all the obvious advice that this forum provided
Checked that the SCART was fitted correctly, checked it was on and RGB enables SCART socket (I actually tried both) Made sure the Sky box was set tp RGB - everything was set as it should? Still poor pixelated picture. I appreciate it's not going to win any awards for outstanding quality at just over £500 but I think it should be better than what I am getting.
Now for the really strange thing. When switching between PAL and RGB on the Sky Box, the picture changes in no way whatsoever. Not an iota??
is this normal, should it not change at all, even just a tiny bit?? I know on my old CRT the picture change between PAL and RGB was massive?? I'm pulling my hair out now, I've removed all video senders, DVD players, AV kit etc. Tried different cables, sockets etc.
Could it be a problem with my Sky Box???
Any advice would be massively appreciated
