Switching AV inputs using the remote on Humax HDR-1000S
warezxs
Hi all,
I'm able to program the remote to work my tv which is great but I cannot find a way of using this remote to switch between the HDMI inputs. I've got a HTPC plugged in beside my Humax box and would like to be able to switch to it without having to use the TV remote. Please tell me this is possible
It was with my sky remote. Has anyone got this working on any TV please? Have tried on both my Panasonic and LG, no joy.
Any advice appreciated :)
grahamlthompson
You must have the remote formerly supplied with the HB1000S, the original remote couldn't control a TV. I don't have this remote but the earlier remote controls had buttons for PVR TV DVD and AV control, these have a source button which does what you want. If not present on the remote you have, look for a Humax RM-F04 remote (it will control your freesat box).
grahamlthompson
This is the remote I have received with my new HDR-1000S(2 weeks old, August 2014). It has buttons at the top for TV and STB but no AV button :(
Here is a closeup picture Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Is my only option to buy another remote that has the AV buttons or something like a harmony programmable remote?
Yes that's the remote that originally was supplied with the HB1000S, and has limited TV control functions. If it hasn't got a Source button then yes I guess you need a different remote.
This one has the capability to control up to 4 devices (via the white device select buttons)
GENUINE ORIGINAL and BRAND NEW HUMAX HD/HDR-FOX T2 REMOTE RM-F04 - In Stock | eBay
warezxs
Okay that makes sense. It does seems crazy that a brand new product's remote is missing this BASIC functionality :mad: Thanks for giving me an alternative. I may purchase that remote as the clicking noise from the current one is VERY irritating anyway:( I assume the one you've referenced does not have a clicking sound on it?
grahamlthompson
No clicking sound. All the buttons aren't on the older remote but I am told all the freesat+ functions can be accessed on way or another. A low end Harmony remote may be the answer.
logiciel
I don't recommend it!
logiciel
It's very restricted in functionality.
A cheaper remote would be better.
grahamlthompson
It's less than £25.00, the OP wants to control a very limited number of devices. Namely two, his HDR1000S and his TV. How much more functionality does it need ?
The alternative Humax remote is about the same price.
logiciel
It's actually the first time I've heard of the 350.
It's listed at £35 and I was thinking of the 300 so you could be right.
grahamlthompson
Hopefully the OP will come back how well it works with the combination he has :)
logiciel
Apparently it's much less restricted than the 300.
warezxs
OP here with an update as promised. I got the Harmon 350 and it works great with the Humax box. Setup was a breeze and I have it working exactly how I want and there is nothing I couldn't emulate from the original remote. I'd HIGHLY recommended it. I have it controlling my Humax Box + TV and HTPC perfectly. Compared to the original remote there's no more annoying clicking sounds either:clap:
grahamlthompson
Thanks for coming back. It could help other Humax box owners.
jeff16765
its really frustrating but I think I have finally worked it out. You basically need to program your humax remote to your tv. Download the humax freesat user guide. At the back there is a series of codes which relate to different makes of tv.
Mine is Sony and there are maybe 10 or 15 different codes. It also tells you in the user guide how to use a code to program the remote to your tv. It is trial and error to find the right/best code.
Once I programmed the humax remote, the home button takes me to av tv settings and then the up and down buttons let me switch av input. Easy when you know how!
Lindz
Hi all,
If you have the right code the pause button will change the av on that remote while in the tv function
LG CX 4K OLED TV Review: The best TV of 2020?
Trending threads
Latest News
TV licence fee now applies to over 75s from 1st Aug
  • By Andy Bassett
  • Published
New H.266 video codec promises 50 percent data saving
  • By Andy Bassett
  • Published
Toshiba launches UL20 4K HDR TVs from £299
  • By Andy Bassett
  • Published
LG GX soundbar launches in UK
  • By Andy Bassett
  • Published
Sky Q updates smart features and adds Disney Plus in HDR
  • By Andy Bassett
  • Published
