switched outlet on amp how to connect
RobTi
Hi looking to connect into the switched outlet on my amp, but the only thing stopping me trying is how to fuse anything connected to it.
Robert
kickitt
you could wire your power lead to a 3 pin socket then use an ordinary plug from the equipment you want to power - bit bulky but would work.
larkone
Why do you need to add a fuse as the main power lead to the amp has a fuse and this would protect the switched outlet and any connected power lead. The device at the end of that power lead will also have its own internal fuse protecting it.
RobTi
Thanks for the reply, i was worried as the 2 pin euro plugs don't come with a fuse and wondered how the appliance was fused.
the reason i ask is i wanted to connect a couple of cooling fans through the amp as they only need to be on when the amp is on and at the moment they are on whenever i switch the mains on for the a\v items.
Robert
