Switched multi-way extension block?
Discussion in 'AV Receivers & Amplifiers' started by nathan_silly, Sep 28, 2003.
  1. nathan_silly
    nathan_silly
    I'm starting to get to the point switching my amps on/off is a bit of a chore- since borrowing a 2 channel amp for the rears- the total number of poweramps now is 5. Plus in the future I might consider a Samson/Crown for my SVS sub(s) so that'll be six:eek:
    I definitely seen a multi-way extension block with one always-on socket, with several other sockets, and a 12V sensor. When the trigger is switched the other sockets are switched on.
    I plan to connect the MC-1 to the always-on, with the other poweramps to the other sockets.
    Does anyone know of a supplier?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    No idea mate sounds like a custom build job to me!!!! MK They electrics people might be a good port of call first as they do a lot of mains stuff.
  3. nathan_silly
    nathan_silly
    Nope, defo seen one going- reasonbly priced too. Should have saved the link or bought one :(
