Switch to the Switch?
steph746
Hi Everyone. I have a Wii U system and thinking about upgrading to the Switch. My main concern is having to get all new games. Also, I like having the discs for games. Does the Switch allow for cartridges rather than downloading games? If it only has 32GB of space, how many games would that hold?
I'm also concerned about having the system being connected online all the time. Is it ok to not have it connected to online communities and just use it "locally"?
Also, I don't think I would use the system as a portable device. Would this be a waste? I'd like to just have it connected to the TV and "pop" in a game that my kids would use.
Thanks in advance.
Inked
It allows for carts, and you can also put in a micro SD card for extra on board storage
You'll need to update games and system firmware online, but I don't believe it requires an always online connection for using games (apart for online multiplayer)
Thanks in advance.
Not a waste at all, the switch looks great on the TV (it's how most of my playing was done when I owned one)
steph746
Thanks very much for your reply. So, the Switch only allows for digital downloads? I'm looking to get the Tokyo Olympics 2020 game:
It seems like there are a couple of purchase options...
How are the controllers for the Switch compared to the Wii U? I like how the Wii U uses the movements. Are the joy con controllers similar?
steph746
Thank you for this. I like the looks of the Switch. Just to confirm though, would this be the best console to purchase now? (I don't want to get an outdated one)...
Lastly, I feel bad about leaving the WiiU behind. I prefer to have just one system (because I feel bad seeing a system not being used), but am debating either not getting the Switch or if I do get the Switch, selling the WiiU on ebay with the games we have for it.
Just feel like I'm starting from scratch...
Davekale86
Get the switch IMHO it blows the WiiU out of the water I Traded in my WiiU when the switch came out went into CEX and got cash then just put the extra to it plus there is some good deals on at the moment if you shop around, yeah the games can be pricey but they are worth it, also the switch pro controller is the best controller I have used in a long time easily my favourite one since the snes pad.. Get it you wont be disappointed
steph746
Thanks. Are the Switch pro controllers the ones that come with the console (the red and blue ones)? Or are you suggesting that I purchase better ones?
Would you say $299 is a decent price for the console?
Davekale86
No they are joycons so you can play two player games without having to purchase extra ones, the Pro controller is like a traditional pad like the xbox or ps4 pad, yeah 299 seems good howeber if you shop around I'm sure you might be able to get a better deal from Best buy or gamestop? I'm assuming your in the US
steph746
Thanks. Yes, I am in the US. Best buy has the same price. I'll check other places as well.
We have the Wii U Sochi game and I will miss it :( No way to play it on the Switch? I thought I read about some adapter that works with a blu ray player...
Davekale86
Unfortunately no lol there is a lot of games on the WiiU that is out on the switch it is a very good console that I find myself playing more than my ps4 haha good luck with your bargain hunting
steph746
Thanks. Would the remotes from the Wii U be compatible with the Switch or the Joy Cons are specific to the console?
steph746
I see. One thing holding me back is the availability of a decent football game. My kids love to play Madden '13 on the Wii U (even though it's pretty outdated). I see that there really isn't a football game available for the Switch. Is there any type of decent football game that I might be missing that could compare to Madden '13 on the Wii U?
Evokazz
I'd buy a Switch and keep the Wii-U, you don't get much money for selling a Wii-U now, and it does still have a handful of exclusive games that are amazing.
cmdrmarc
There's no decent football game on Switch sadly. EA decided not to support it. Even for FIFA Soccer they only supported as far as FIFA 19 - 20 is just the "Legacy" edition which is 19 with updated players and teams.
richardb70
Does the OP mean "soccer" or "American football"?
As above, keep the Wii U. You're asking a whole load of questions that a quick google would have answered :).
To clarify, the Switch allows for carts and also digital downloads. Price-wise, there's not usually much in it but some people (like me) prefer the latter for convenience. You'll need a good micro SD card (128Gb at least) if you're planning on downloading anything. The eShop has loads of free demos which are always worth a go. You can also buy games from different countries, see the other thread.
All consoles will come with a dock and a set of joycons (which only differ by colour). You can get additional joycons (for 4 player Mario Kart etc), third party controllers and the very expensive Pro controller (which resembles an Xbox controller).
skysnapper
No you don't it comes with 32gb internal memory i dint use a card for the first 6 months and i had a coupe of Nintendo first party games and 10 indies on there.
It depends on how big the games are but for the most part internal is fine initially.
richardb70
Hmmm, I'd still get one anyway. Some cart games involve a whopping download and 32Gb fills up fast. But yeah, does depend on what games you go for, indies are generally much smaller.
Similar threads
Trending threads
