Quantcast
Switch Speakers between Amps
sgbooth
I have 2 pairs of floorstanders wired across my hi-fi amps.
I would like to use the speakers for my new AV amp as well.
Is there a good quality & value switch that will let me do this without having to keep changing the connections ?
For example, select switch position A and the unit accepts the signal from the hi-fi only. Select B and it's from the AV amp only.
Regards and thanks,
Stuart.
MaturityDodger
The one I've got is the only one I've seen that looks solidly-built and reliable, and that I'd trust to go in a good-quality system.
TC-7220 AUDIO ROUTER
Connect up to 2 amps and up to 2 pairs of speakers, and switch between any combination.
sgbooth
Many thanks, that's what I'm after.
Expensive ....... but more so would be the consequences if the speakers were to "fry".
Thanks again.
