Switch solution to swap front and rear speakers?
Discussion in 'Home Cinema Speakers' started by ms8qt, Jul 11, 2003.
  1. ms8qt
    ms8qt
    Hi all,
    I could really do with some help if poss!
    Apart from my big install there is another room with a Sony Home Theatre (DVD/Amp all-in-one) unit.
    My requirement...
    To put a switch in between the speaker cables of the front/rear speakers and the main unit (Amp)
    - When the switch is in position A then all works as normal.
    - When the switch is in position B then the front speakers become the rears and the rear speakers become the fronts!
    - it needs to be as cheap as poss too!
    Any ideas really really appreciated.
    Thanks,
    Mark.
  2. Garrett
    Garrett
    Apr 21, 2001
    40,255
    2
    167
    The best thief you’ll never see.
    +6,673
    QED do a range of switching boxes try here http://www.qed.co.uk/acc/index.html
    Also there is an other place called something like Lechtronics??? that also do a range of switching boxes. I will look in some of my mags for them not unless someelse can point a link to them.
  3. Garrett
    Garrett
    Apr 21, 2001
    40,255
    2
    167
    +6,673
  4. Sunil
    Sunil
    Apr 27, 2003
    93
    London
    If you are switching around your fronts and rears, wouldn't you need to switch your left and rights too?
  5. ms8qt
    ms8qt
    Thanks to all that replied - I'll take a look at those websites.
    Yes, you're right - left and right need to be swapped too but this isn't entirely necessary as I'll only be using the rears and fronts when playing CDs in 2 channel audio (so it won't matter that much that the left and right are the wrong way)
    I was considereing buying a smll box, few switches, connectors, etc and making my own control unit (I'm not bad at the odd bit of soldering!).
    Mark.
