switch mechanism
Discussion in 'Desktop & Laptop Computers Forum' started by robertflack, Aug 19, 2005.
  1. robertflack
    robertflack
    does anyone know of a piece of hardware that can be bought which is essentially a light switch type mechanism which plugs into a USB port? I want to have a switch trigger various actions on my computer...eg: soft music and a roaring fire screensaver start playing
    any ideas!?
  2. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    You might be better off trying some of the remote controls, as they can be made to trigger things and there is some good software which allows you a lot of flexibility by replacing the driver level.
    Otherwise I'd look along the lines of home automation equipment. There is a forum for this here but I've never looked. There are other forums on other sites that look at home automation.
    Good Luck in your Search
    Rajiv
