Swisstec 32" at the CO-OP
Discussion in 'LCD & LED LCD TVs' started by Petrovski, May 20, 2005.
  1. Petrovski
    Petrovski
    Feb 8, 2005
    5
    Had a look today at a Swisstec 32" for £699 at local CO-OP.
    Manufactured by Sky media Brochure Here
    Reasonably good looking for the price although unfortunately I haven't seen
    it working. It was on display minus the detachable speakers.
    Had a quick look at the manual : DVI, VGA, Two Scarts plus others I'm not interested in [RF + S-Video I think].
    I believe it only has one analog tuner and the DVI doesn't have HDCP.
    Anyone got one of these or seen one working?
  2. Petrovski
    Petrovski
    Feb 8, 2005
    5
    Had another look at manual which is very poor on input specs.
    States that Scarts are for composite signal only! [they only show
    them as suitable for VCR].
    Manual advises if you want to connect an RGB set top box you must use
    VGA :confused: or DVI. Not much good for Scart Freeview boxes.
    Has anyone got one of these? I still haven't seen one in operation.
  3. seawitch
    seawitch
    :) Hi there
    I got the 42" from Co-op for £999 and I love it.
    Haven't a clue what you are talking about socketwise as terminology is not my thing with Televisual equipment; but you seem to be able to do most things with it. It never gets up to do the ironing tho :(
    One of my better purchases so far :clap:
    regards
    Sea x
  4. peahead
    peahead
    Dec 14, 2002
    2,840
    St.helens
    +271
    scart no1 should take a rgb signal from freeview as its fully wired socket the second scart is half wired which is composite.
  5. Petrovski
    Petrovski
    Feb 8, 2005
    5
    Seawitch: Please confirm you have a 42" LCD as Swisstec don't seem to make
    one but *do* make a 42" Plasma.
    What's the model number of your set?
