We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
swing out wall bracket
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by kevandalice, Oct 29, 2005.
  1. kevandalice
    kevandalice
    Oct 27, 2005
    440
    43
    +125
    can anyone recommend a wall bracket that will swing out 90 degrees from flat against the wall, one that will cope with a 37 inch plasma?
    regards
    kevin
  2. av2diefor
    av2diefor
  3. JayList
    JayList
  4. HenryHonda
    HenryHonda
    Nov 13, 2000
    595
    46
    UK
    +149
    Not cheap by any means - £460-£500 (or more :( ) depending on where you buy it...
    - but rock-solid, high quality engineering. You can even fit a motor with R/C later if you like :cool: :
    Future Automation
  5. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
