Sweetspot Red Saturation
Discussion in 'Desktop & Laptop Computers Forum' started by Hawklan, Apr 18, 2005.
  1. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Just installed my sweetspot card and find that the picture is great from the Tivo (very Sky like) into it apart from one thing "everying is saturated with red"
    Within Dscaler I have the sweetspot video source as RGBS video outputs tried them all with the same colour results
    Any ideas guys
    Many thanks
    RON
  2. DaveP
    DaveP
    I had troubles with mine when I first installed. Are you using the scart to RGB?
    I assume you are.
    Despite the high cost of this cable the build quality sucks. I found my problem to be with the core shorting out to the shield on the Red cable.
    The clown who soldered mine stripped the inner core right back to the outer plastic cover so it was bound to happen. If I were any good with a soldering iron I'd remake them.
    I bought mine secondhand so no warranty but if you have just bought yours I'd demand a replacement.
    Dave
  3. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Hi dave
    Yep I am using the same cable
    I bought mine of here - I guess I'd better get my soldering iron out
    How did you get round the problem?
    Many thanks
    RON
  4. DaveP
    DaveP
    TBH I have done no more than seperate the short.
    I'm re-cabling shortly and the cable will be connected via extension leads. When I've done this the dodgy wire will be tucked away behind my equipment.
    If you need to diagnose which is the dodgy lead just remove each colour in turn, and when the picture hue doesn't change you've found the lead.
    Dave
  5. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    I was hoping that it was some sort of driver conflict as initially for before I used Powerstrip it worked with really good results none of the blockiness that you get with Tivo - But a cable problem makes more sense, especially as a new puppy that I have has been running around like crazy behind the cables so any dodgey wire may well have been worked loose
    Many thanks
    RON
  6. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Hi Dave
    Hi yep it's the cable (Bummer) green lead and now that I had a look at the others to see what they should look like the Blue has gone as well
    Not being that handing with wiring I'm not sure what you mean here
    Could you let me know waht you had to do to solve the short
    Many thanks
    RON
  7. DaveP
    DaveP
    TBH when I read it back, I didn't understand it either! :oops:
    When I had a steady hand and thinner fingers I did a fair bit of soldering using co-ax cables. You should always leave the insulation on the inner core longer than the exposed sheilding cable. You then pull the shielding cable back, away from the exposed inner core and twist it out the way.
    My cable has the inner core insulation cut back to the same point as the outer plastic cover thus all bare wires are the same length.
    I hope I have explained it better!
    Here is a picture. It is for a different kind of plug but you can clearly see the inner insulater extending beyong the shielding cable.
    I had to seperate several very thin wires of the shielding from the inner wire using a cocktail stick. It's not a permanent (or safe!) fix but it got me working. If yours has physically seperated you'll have to resort to solder!
    Dave
  8. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Ah!
    Now I see what you mean - Both of insulators are the same length
    So on mine the inner core and outer shielding cables are very much at risk of touching each other just a little twist will do it
    I'll pop down to Maplins today and source a cheap soldering iron
    I agree with you for the price the build quality leaves alot to be desired
    Many thanks for the helpfull explanation and picture
    RON
  9. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Hi Dave
    All sorted (A few burnt finger tips)
    Picture Quality is a great improvement over straight Tivo into the Plasma via the JS RGB to VGA box
    Now if only I knew what I was doing with Dscaler and Powerstrip
    Many thanks
    RON
  10. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Dont like the sound of cable build quality that sucks ! ( glad its not one of mine! )
    Would anyone be willing to loan me a cable for a few days so I can see about building high quality cables for the sweetspot card?
    I smell an opportunity ;)
    Mark.
  11. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Hi Mark
    I'd be happy to lend you mine
    Please excuse the really, really bad soldering
    Drop me a PM with your address and I pop it in the post
    Many thanks
    RON
  12. DaveP
    DaveP
    Glad to hear you got it sorted.
    DScaler should give good results "Out Of The Box". I'm certainly happy with the picture I get.
    Powerstrip on the other hand, is a Dark Art!
    Dave
  13. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    +171
    Hello Ron,
    Sent you a PM,
    you will receive an improved cable in return for the favour (free) :)
    thanks,
    Mark.
  14. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    What a very nice bloke
    I can't wait
  15. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Hi Dave
    I like Dscaler too, it has even seemed to improve the contrast on my Plasma
    My only complaint is that I sometimes get a pixel wide bright line to the left and bottom of the screen even after I have adjusted the image width / position - I'm sure a bit of tweeking will sort this out
    Regarding the auto calibration did you get it to work? - when I tried it the results gave a very dark and blurred picture
    Quick question what Pal output option are you using?
    Powerstrip however is very scary
    You just don't know what to change
    I sit there wondering things like
    - Do I increase or decrease the refresh rates
    - Should I stick to 1280 by 768 (the resolution of my 43MXE1) or up/downscale like some of the peeps here do
    - Push things to far and POW and blank screen
    I need to do a prowl here and on the web to find out what I should / should not bother adjusting
    Many thanks
    RON
