Sweetspot and PVR
Discussion in 'Desktop & Laptop Computers Forum' started by philipb, Jun 2, 2004.
  1. philipb
    philipb
    Mar 6, 2002
    2,083
    63
    Swindon
    +170
    I know Showshifter is the "official" PVR software for Sweetspot, but wondered what else works with the card and how good it is. Main use would be archiving from Sky+ to PC hard disk, so MPEG2 or 4 encoding needed.
    Comments welcome.
  2. Alex Simon
    Alex Simon
    Hi PhilipB
    Funnily enough we've just put a user-review on our site that mentions a great sounding combination. (review right at the top of the page)
    http://www.pluggedin.tv/sweetspot/reviews/index.html
    Basically any software that supports WDM drivers should work - there are absolutely loads including some we've mentioned in our faq.
    http://www.pluggedin.tv/sweetspot/support/faq.html
    We've focussed on ShowShifter mainly because it was the single biggest feature request that we had over the first few months after launch. Also Colin Tinto at ShowShifter was very helpful in the testing of our WDM driver.
    Hope that helps
    Alex
  3. philipb
    philipb
    Mar 6, 2002
    2,083
    63
    Swindon
    +170
    Thanks for that.
