Sweet point/s for Barco D 808 S
Discussion in 'Projectors, Screens & Video Processors' started by artoj, Nov 21, 2004.
  1. artoj
    artoj
    Nov 21, 2004
    80
    I would like to hear what resolutions and ref.freq. have you find to work really well with a Barco D 808 S with a HTPC front end.
    Is your preference higher resolution with a lower fef.freq or vice versa, f.ex for PAL 1440 x 1152 @ 50Hz or 1440 x 864@ 75 Hz.
    As I watch both PAL and NTSC DVD´s, should I use different settings for PAL and NTSC and how about Film/Video ?
  2. Tom.W
    Tom.W
    Nov 16, 2004
    1,065
    +104
    Iv'e been using 1440x720 P @ 48HZ on my BD-808 with very good results.Even at 1440x 920p with good focus theres only a slight scan line overlap...
  3. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,366
    63
    Norfolk
    +156
    For PAL DVD I'd go for 75Hz refresh. For NTSC, 72 Hz. Software playback using ReClock, so you can get the frame rates right. 48 Hz too flickery (and not good for PAL DVD which is 25 fps).
    Shoving test cards up on my BD801s shows that it resolves clearly 768 lines (4:3), and 960 lines (same ratio) are visible but greying. 1152 lines grey out.
  4. artoj
    artoj
    Nov 21, 2004
    80
    I would agree that 75 Hz is definitely the way to go for PAL, haven´t yet to test NTSC. :smashin:
    Since PAL is 720 x 576 = 1.25 but on the other hand 4:3 = 1.3333 and 16:9 = 1.7778.
    So when I watch a 4:3 full frame material should I use 1.25 or 1.3333 "ratio resolution", f.ex 1080 x 864 or 1152 X 864. Or is it at all necessary to use either of those "ratio resolutions", perhaps 1440 x 864 could outperfom either of those. :confused:
