Swapping standard sky box for sky +
smiffs
Hi folks, first post but already had lots of advice previously so thanks for that....
I have a standard Sky box, single cable from dish. I want to buy a Sky+ box, simply to use as a PVR and use the basic Sky + facility of pause, rewind, series link etc.
I am not bothered about the second cable from the dish (I have full sky + elsewher in the house) and recording 2 programmes at once etc.
If I swap the original box for a sky+ box, what facilities will or will not be available? Is it indeed that simple? :eek:
Thanks! :smashin:
kdc
You'll get live pause and rewind aswell as the ability to record the programme you are watching but as you can imagine you don't get the ability to record something else....
fernandez
AFAIK you'll also need to phone Sky CS to have the + facilities activated on the card
naziern
Hi I have bought a second user sky+ box from fleabay for the same reasons as you. I have a bog standard sky box at the moment without a valid subscription as I only watch the freeview channels.
Do I still need to pay Sky for the privelige of using the Sky+ box to record programmes? if so any ideas of cost?
Naz
F1DashNine
Similar issue:
After my HD upgrade, I moved the Sky+ box into another room to replace a Digibox. So it's still on the single dish cable, but with Multiroom.
I put the Digibox card into the Sky+ box and paired the card up with Sky.
Initially it looked good, but some (non clashing) recordings have since failed, and I couldn't playback some previous recordings (made with the original master card, which is now in the HD box). I get "Recording Interrupted". Sky+ worked fine before move.
After I attempt to playback a non-playing recording I can't playback one that did playback again without rebooting the box
Rewind, live pause, etc. work OK.
Does it matter which of the two connections the single dish cable is in?
Should I be able to play back recordings made with another card?
Don't understand why it doesn't work properly!
Broadz
Similar issue:
Already answered by myself (WW) and riando on DS.
mentm
SKY+ with one aerial will only record if the box is already on the right channel, since sky normally uses the second aerial to record and will just return a signal not received error. It's easy to run a second cable if you have a spare socket on your lnb.
mn9ajas
I'm interested in doing exactly the same. I would be going from a standard sky setup (with skysports package) to sky+ but just have a few questions:
1) Can someone just confirm that it won't cost any extra to use the Sky+ facilities once installed (with a double coax cable and suitable LNB) as I have the sports package.
2) Do sky charge you for pairing the card with the new box?
3) What are the better make sky+ boxes to go for?
4) Where is the best place to get a reasonably priced 2nd hand box other than Ebay?
Broadz
What does the sports package have to do with anything? Sky+ is free to anybody who subscribes to any Sky TV.
Only the cost of a phonecall. Which is free if you have SkyTalk.
Pace seem to be most people's favourite. I've had Pace and Amstrad Sky+ boxes - both were fine.
Don't know of anywhere else that openly sells second hand goods - maybe a car boot sale or a jumble sale? Free ads? Classifieds in a local newspaper? Or ask around in case any friends have upgraded to Sky HD and no longer need their old Sky+ box.
mn9ajas
Cheers Broadz for your comments. My reference to Sky Sports was because I remembered when Sky+ first came out you only got it free if you had Movies or Sky Sports packages, otherwise it was £10 a month more.
Having looked at Sky's site again, I notice this stipulation has gone now.
