swapping router
Discussion in 'Virgin Media Broadband' started by dmpt6985, Mar 1, 2013.
  1. dmpt6985
    dmpt6985
    Mar 1, 2013
    3
    hi i have a virgin router but i would like to swap it for a N 900 TL-WDR4900 wireless dual band giga bit router is it as easy as unplugging the old one and plugging in the new one or will i have to ring virgin to get it changed
  2. stevelup
    stevelup
    Aug 13, 2002
    6,780
    Swindon
    +1,284
    Exactly what do you have now? Do you have a modem connected to a router, or do you have a Superhub?
    If it is the former, then just swap the router over, reboot everything and you should be good to go.
    If it's the latter, you will need to keep the Superhub and put it into 'Modem Mode' and then connect the first LAN socket on the Superhub to your new router.
    In neither case do you need to speak to Virgin.
  3. dmpt6985
    dmpt6985
    Mar 1, 2013
    3
    i have a superhub atm how would i put that into modem mode
  4. stevelup
    stevelup
    Aug 13, 2002
    6,780
    Swindon
    +1,284
  5. dmpt6985
    dmpt6985
    Mar 1, 2013
    3
    thank you verry much i will do it as soon as i have the new router
