Swapping Mobos and Processors
Discussion in 'Desktop & Laptop Computers Forum' started by Steve Bate, Oct 22, 2004.
  1. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    I've got 2 PC's one is currently a Server and one a HTPC the Server has a more powerful CPU & more recent mobo are there any real config issues with just swapping the mobos over? I want the extra grunt the server CPU has for FFDShow but I dont really want to reconfigure each PC.
    Steve
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Windows may well not like it, you'll probably have to re-install. The problem is the low-level chipset drivers Windows installs often won't work on a different mobo, even the same brand. Even if it boots you may well have problems with it as Windows tries to install the chipset drivers for the new board it's seeing.
    If you really don't want to re-install then I wouldn't suggest you try unless you have a tool like Drive Image or Ghost to take a system image in case things go pear-shaped.
  3. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    B**ger, looks like ghost then, but it took me ages to get my HTPC just right, I hate reconfiguring a working system :(
    Steve
  4. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    527
    North Cotswolds
    +3
    Yes, you're asking for trouble trying to do a straight swap. Things may work but you'll get unstability and potential slowdowns.
