It is unlikely that they are the same make and model of HDD - however if it is a SATA HDD then it is likely to work. What make, model and size is the Samsung HDD?
Well it should be a CE/AV drive. You would need to delete all partitions on the drive so that the Foxsat can create the several partitions it needs and formats them.
