Swaping Hard Disks Over
Discussion in 'Satellite TV, Sky TV & FreeSat' started by cebs_uk, Jan 16, 2005.
  1. cebs_uk
    cebs_uk
    Jan 25, 2004
    2,537
    Manchester
    +416
    It probably been asked before but can I swap between 2 hard drives without losing the programs stored on them both or do they need a reset everytime they are put back in the sky+.
    The reason I ask is my first drive is full and I want to tape some more before I can free up some room.
    Any advice would be cool.
    Cebs
  2. cebs_uk
    cebs_uk
    Jan 25, 2004
    2,537
    Manchester
    +416
    So has no-one ever removed a drive with programs on it and then replaced it.
    Guess I might have to be the first but somehow I doubt it..
    Cebs
  3. chic
    chic
    Jul 1, 2001
    5,976
    glasgow
    +871
    as far as i know the old programmes stay on the drive and will still be there if you decide to put the old drive back in, check out the sky+ forms at www.digitalspy.co.uk for more info
  4. chris4817
    chris4817
    If I remove the original 40g hard drive and replace it later the programmes are still there. However, I have also done this with a larger drive and the box deletes them.
    Hope this helps.
  5. 7Seven
    7Seven
    Did you put the larger drive back in the same box, or in a replacement box?
  6. chris4817
    chris4817
    Yep, same box.
  7. 7Seven
    7Seven
    This concerns me a little. If I record loads of TV onto a 160GB disk and have to remove it tempoarily for some reason I'll lose the progs. Especially if the box needs replacing, I pop the original disk back in and I try the drive in the replacement box. If it doesn't work again in the same box, it's less likely to work in another box. I need to find out how many others have seen this problem to see if it's common or rare.
  8. cebs_uk
    cebs_uk
    Jan 25, 2004
    2,537
    Manchester
    +416
    Hi guys
    Cheers for the info, I am in the same boat my 160 was full and I needed to tape some stuff this week and had my original 20 drive sat there. In the end I didn't risk it yet and deleted some stuff to make space but if anyone has done those tests where they fill their drives full of stuff just test I wonder if they have unplugged and got a good result?
    As mine is working it's way back to 100% I may have tp try at the weekend anyway.. don't you just hate the new year and all the new shows it brings...
    Cebs
  9. 7Seven
    7Seven
    It's a love/hate relationship!:)
