Swap Magic 3.3 Help
Discussion in 'Nintendo Forums' started by Mak10, Jan 11, 2005.
  1. Mak10
    Mak10
    I have a few questions about Swap Magic 3.3
    I am trying to simply load a non-backup game to get framiliar with Swap Magic. As I understand, you must put in a non-backup game to refresh TOC, the screen then tells you to insert program disc. By using the slide tool I simply open the tray and leave the original game in the tray. When I close the tray with the slide tool and press X, the game does not load at all and the screen will not change until I press eject. If however I start PS2 with swap magic disk, then use eject button to load original game, it works fine. Only when I use the slide card it doesnt work. I have also tried the following step by step:
    -Boot PS2 with swap magic
    -Use slide card to open CD tray and swap the "swap magic" CD/DVD with an original game
    -Press X
    -Game does not load
    Any help would be appreciated. Thank you
