SWA 3000 question
Discussion in 'Home Cinema Buying & Building' started by charalambosnik, Sep 16, 2007.
  1. charalambosnik
    charalambosnik
    Jun 9, 2007
    19
    I was wondering if i can use the SWA 3000 wireless kit with the new HT X250 system.
  2. TheManTheMyth
    TheManTheMyth
    Yes you can use the Wireless module but I have found that when watching stand/digital tv channels (only broadcast in Stereo) you can hardly get any noise out of the rear speakers and they are quite fuzzy. It may be the way I have it set up (Corner of a Sofa in the way). Works great with dvd films and would be great for a big room (No Crappy wires all around the walls).
    :smashin:
