DanielB
Established Member
Miron said:Believe me he knows what he's saying here. Here in Austria they subtitle them (and in Germany they subtitle both )
I have many languages to fight with anyway , that's why I gave up long time ago
Back to the thread,
Daniel, I am somewhat confused with this one. Do you mean bypass collapses after some time, or processing collapses when fed over SPDIF with DTS96/24.
I guess it is latter. In that case it seems very strange. One stupid idea for testing: Have you tried to switch T2L off? It seems DP looses something of incoming data or can not lock correctly. It can also be that one of the converters drops off but that's unlikely, why only in 5.0? Does it collaps on all channels or only on some of them?
It sounds more like some failure than like SW bug to me.
I guess Steve is the only one who might give you better answer here anyway, so let's wait for him.
Hi Miron
you're fighting with subtitles
My AV32R has no bypass - it's from DVD32R or Denon DVD2200 pure digital to the AV32R. I had the same idea, with T2L, i switched it off, but with no success. You misunderstand someting - not only in 5.0 - i explain it:
Problems happens only with DVD-A's, with DVD-V's it's perfect.
Problem happens with DTS and DTS96/24 decoding.
First i thought the failure happens only in on 5.1 system but it also happens in an 5.0 system, but less often.
The "Blue Man Group" Complex DVD-A with DTS96/24 works perfect if the AV32R is setup as 5.0 system. If it's setup as 5.1 the failure happens.
The REM DVD-A produced the failure on both ways.
To reproduce the error, simply put the DVD in and press play - and wait.
Blue Man Group DVD-A - Track 3
REM DVD-A - Track 2
If the failure happens you can toggle surround modes or inputs - then it works again for a few minutes.
Regards
Daniel
