SVT-150 power problems!
Discussion in 'Projectors, Screens & Video Processors' started by atrade, Jul 10, 2005.
  1. atrade
    atrade
    Having major problems with my Seleco SVT-150!
    It was working fine for ages and then yesterday i went to turn it on, it started to power up and then went straight back to stand by. It seems to only do it when there is a composite signal attatched
    When there isnt i just seem to get half a picture
    Anyone any ideaS?
  2. gazzzman
    gazzzman
    Jun 15, 2005
    36
    hi there!
    I assume when you sa "half a picture" the top is ok and it gets darker towards the bottom?
    it sounds like it is on the verge of going into protection mode (it blanks the pic progressivly towards the bottom of the screen)
    to check this you will have to take the top off (be carefull)
    when the top is off switch on and put into standby
    looking from the back on the right hand side near the front edge of the defl board you should see one iluminated red led..
    when you have found it come out of standby if the led remains lit at all..
    then the system is entering protection mode!
    when you get that far pm me and I will explain what to do :)
    DO NOT DISTURB ANY SETTINGS BEFORE YOU TELL ME OR YOU COULD DAMAGE THE TUBES OR YOUR POCKET :oops:
    cheers
  3. mrfluffy
    mrfluffy
    May 3, 2005
    244
    +43
    I'm having similar problems with my SVT150, after a year of faithful service. I don't get half a picture though, I get a full picture, with occasional horizontal flickering lines that get progressively worse, causing the picture to collapse and the projector to enter standby.
    Gazzman, in your expert opinion, is this being caused by the power supply? If so, I'll buy another one from AJ audio.
  4. atrade
    atrade
    Hi Gazman,
    The picture doesnt get darker towards the bottom it just has no bottom!
    It now no longer produces a picture at all, when the PJ is powered on it just flicks into standby after about 4 seconds :(
    I know its an old unit but it has been a labour of love for me and would love to get her going again!
    Any ideas?
  5. mintminty59
    mintminty59
    Jan 19, 2005
    55
    I have 4 Seleco projectors doing that exact same thing , power on tubes start to fire whap back into standbye :S. I have a stack of 150 , and 100 parts here tubes , lenses e.t.c. Ohh and does anyone know where to get a remots for a SVP350+ (digital convergance model) I need to defung this baby and get it fired up.
  6. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Hey Mintymint. You can do a full convergence with the user remote - the grey one. Let me know if you need one of those, I can get hold of them.
    Regards
  7. mintminty59
    mintminty59
    Jan 19, 2005
    55
    Yes please chris I dont have any remote at all.
  8. BobbyBlaze
    BobbyBlaze
    Jan 17, 2005
    188
    Sunny Cardiff
    +9
    If more people need these then it might be worth doing a search for replacement remotes on google. My 320+ remote died and I got a replacement (different layout but full functionality) for 20 quid. :smashin:
    Regards,
    Rob
  9. turner2
    turner2
    Hi Gazzzman I am having the same problem as person below, when you switch on all three colours light up but after 6 seconds it all goes onto standby, followed what you said untill come out of standby, help where is standby:suicide: and what do I do next Jane
  10. kamilmaj94
    kamilmaj94
    Jul 5, 2016
    3
    4
    Poland, Wroclaw
    Hello gazzman! I have same problem!
    Same projector and same case! And yes, led on the right side is lit up! What should I do?
