svs sub power lead
Discussion in 'Subwoofers' started by fama, Nov 17, 2004.
  1. fama
    fama
    Jan 28, 2002
    142
    whats best to do with this lead replace it
    or cut it and fit a plug?
    what are the cable colours ie live neutral
  2. Smurfin
    Smurfin
    Aug 13, 2002
    20,797
    +4,161
    Go out and buy a kettle lead from Maplins, or make your own:)
  3. Nimby
    Nimby
    Jan 27, 2004
    9,201
    The Danish Bacon Factory
    +669
    Doesn't that require you have a mains socket very close to the sub?
    I needed a six metre long mains cable to reach the sub next to my right speaker. So the original SVS cable, though very generous in length, wouldn't reach.
    It took ages, but eventually I found a short cable in a DIY superstore with removable plugs. Then I bought 6 metres (about 20 feet) of 1.5mm^2 flexible rubber sheathed cable. I had to ream out the 2-pin subwoofer plug slightly to take the bigger cable diameter. The larger than standard cable was to take care of the unusual length without losing current carying capacity for the subwoofer's peak demands on transients. The rubber sheathing is very floppy and lies nicely flat in comparison with the usual PVC
    The SVS is unearthed. Since the cable is two-core the polarity doesn't matter much. Provided you don't connect anything to the earth pin in the UK 3-pin plug! Since I never removed the plugs from the original SVS cable I cannot say what colour coding they use. If you have to remove the plug anyway to fit a 3-pin plug to replace the USA 2-pin you will quickly discover which colours the core insulation uses. If it's red and black then use red for live and black for neutrel.
    Did I really write all this just to discuss fitting a 3-pin plug to a 2-core cable? :D
    I'll get my anorak. :blush:
    Nimby
  4. Kazman
    Kazman
    Jan 14, 2004
    5,266
    Luton, Bedfordshire
    +139
    I just used a two pin USA to three pin UK converter, one that is earthed, and it seems to be working just fine for me :)
    Nice anorak Nimby :Grin:
  5. Nimby
    Nimby
    Jan 27, 2004
    9,201
    +669
    Nah. You don't want to do it like that. It's an extra connection in the vital mains feed to a hungry amp. :blush:
    You're too kind. :D
    Nimby
  6. Pollywoggle
    Pollywoggle
    Aug 14, 2000
    1,442
    South Shropshire
    +81
    I'm using an old printer lead on my pb2+.
  7. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    Just cut the 2 pin plug off, i did. The wires are blue and brown connect a three pin plug job done.If thats too hard to do go out and buy one :lease: .
  8. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    I just used the one i made for the 309:)
  9. cwoj
    cwoj
    I have a 5mtr IEC lead spare in the office, its been unused, if you pm me on monday i will post it out for you...good will to all men etc.. :hiya:
  10. fama
    fama
    Jan 28, 2002
    142
    THANKS
    thats good karma,
    I wasnt trying to be stupid here just did not want to waste the
    power lead it came with,I did not realise the polarity was
    unimportant didnt want to damage anything,however needed a long lead
    and have since found one which I think came with a printer.
    thanks for all advice and offer.
  11. cwoj
    cwoj
    no worries.
