kick ass sub
For movies SVS is probebly the best speaker system that you can buy cheap. If you want to go better you'll probebly have to but M&K speakers and those are a lot more expensive (especially if you want something that beats the SVS's).
5.0 systems are ment to go with a sub. otherwise the concept is quit lost. The subwoofer is just as imortent as every other speaker in your system. I strongly recommend a sub. that counts for any speaker system.
Maybe you can start with something cheap? try BK, they have a few good subs where you can start. the BK gemini or BK xls200 for instance. Later you can always upgrade to a BK monolith, SVS PB10 or SB12+.
