Samurai303
I'm currently looking to rearrange my living room and in the process upgrade my speakers/amp.
After much reading I'm thinking that the best bang-for-buck is the SVS on the powerbuy but before I go ahead I would like your views on:
a) whether they will work well in my room (see attached images) and
b) if there are any others worth looking at for the same money or less.
So you have an idea of size, measurements are 4.2m x 4m with the longer wall being the width. Viewing distance on the proposed layout would be around 2-2.4m. Room is open plan with open stairs & 2 archways on the bottom left & right. Rear speakers will need to be wall mounted at virtally ceiling height above the archways to get them in the right place.
I'm looking to get an Onkyo 705 or 805 amp - just trying to work out if I want to spend the extra 200 notes.
Current setup is a Pioneer VSX D812 amp to Kef 1005 speakers & sub, with usage mainly TV (Sky-HD) & DVD with about 5% music added to the mix.
