Pecker
- Joined
- Dec 26, 2004
- Messages
- 22,825
- Reaction score
- 4,671
- Points
- 4,123
Will do.
I'll be comparing it to mw old REL Storm.
Steve W
Steve W
Will do.
Steve W
Steve the new sub should blow your old Rel Storm into next week have more output and give a lower response! Plus if you like to play music as well , it should have a lot more punch and better timing..............And for movies more output and slam! but it will take a good three or four weeks before it starts to give its best depending on how much play it gets and just get better and better from there on?
can't you just leave it running full time cycling through a set of files containing all relevant colours ?I'm getting my new projector (also arrived today) calibrated, but I have to put 100 hours on the lamp before I do.
That's good news lol!! Which pj did you eventually go with.
I'll remember that one if i ever get an LCD pj then!Leaving a hot light shining on LCD chips for a long time = bad idea.
I've seen the results.
They're not pretty!
Steve W
You know, the problem may be sorted with the reflective technology, but I'm not going to take the chance.
DLP, on the other hand, is absolutely fine. It's possible the continued heat might not be good for your lamp, but you can always buy another lamp.
Steve W
Bit late, meant to post yesterdayWill do.
Steve W
On adjusting with REW Sim some more the best response achieved in your room Steve is to use two subs at center front and rear and then to place your mlp at 2m from the rear wall gives and nice and flat response before any eq is added! It even looks a lot better through the xover region................................Another sub at all stated positions would sound awesome and alleviate the sat in a bit of a null scenario.
I'll let you know when I can afford a second sub.
Steve W
Hi steve! Can i ask at which position have you got the phase button set too.
