SVS SB-2000 Subwoofer Review
Steve Withers
Reviewer
Good timing - my next upgrade is to replace my old REL Storm sub, and I've been wondering whether to get the SB-1000 or the SB-2000.
May I ask, what are the dimensions of your room, and where did you place the sub?
Cheers.
Steve W
I'd definitely go for the SB-2000, it's a bit more but you're getting so much for the extra cost. I usually end up positioning a sub at the side near the front but I'd have to check my exact dimensions, I can't remember off the top of my head. I wouldn't worry though, the SB-2000 might be compact but it can definitely handle a sizeable room.
Butters
Mmm - been thinking about changing my SVS SB12+ for some time now - purely down to upgradeitous. Would this be considered a step up?
Simba
how would this compare to a mission m5as - dramatic difference?
Dans1210
I would also like to know if its much of an improvement on the sb12nsd...on another note i cant stand that black ash finish, the charcoal vinyl wrap was better than that!
badboymick
I currently have the the PB1000 which I find is a great with movie sound effects, but I find a bit sluggish with drums etc in music. Is the SB2000 similar in bass depth performance but tighter compared to the PB1000 ?
Steve Withers
Reviewer
Yes badboymick, that's a very good description of the SB-2000, plenty of depth but a bit tighter with a touch more control.
Russ 66
This, along with the metal grille is what put me off, for the same money the new XTZ 12" cinema sub looks good.
I think if you can hide it out of the way one or even better two SB 2000 would be very good.
badboymick
Thanks Steve for your reply. Will be purchasing a SB2000. Originally got a PB1000 to replace a Ruark Log-Rhythm sealed subwoofer. I found the PB1000 to be absolutely superior to my old sub for movie effects but when listening to music, for example: Through The Never from Metallica I found the PB1000 not to be as sharp as my old sub. Judging from your review, the SB2000 should give me the best of both worlds.
golden phoenix
thanks for that review steve, will put this on my shortlist when i upgrade my sub hopefully in the next 6 months
Hi Phil (or Steve),
What general sound differences would you find between the PB-2000 and the SB-2000 ? I rarely listen to music, only movies. Also will either be a vast improvement over my SVS PC12 NSD. As Steve will be aware, I'm using a Pioneer SC-LX83 for power with KEF KHT6000's. The reason I ask is that the wife would prefer a 'box' sub hidden out of view rather than our current one that climbs above the back of the settee like the 'Leaning tower of Pisa.'
Chris
Steve Withers
Reviewer
I haven't had a chance to review the PB-2000 yet but obviously that is ported and pretty big, whilst the SB-2000 is sealed and much smaller. So given your wife's views the SB-2000 might be a good choice, it's certainly ideal for movies and has plenty of kick.
Paulyc1864
Guys, I have a room similar in size to Pecker's and have been looking to upgrade my Rel Strata 3. I sought advice from SVS having considered the SB 2000 and the PB2000 and received the below advice.. Hope this assists.....
If you listen at loud to very loud levels, for maximum impact in a smaller package, consider the SB13-Ultra. For moderate to loud listening levels, the SB-2000 could fit the bill. Both subs will mate nicely with your Monitor Audio speakers and complement the rest of your system with accurate, authoritative bass.
dolofsson
Performancewise this seems to be a great choice of sub. Would really like a few more choices when it comes to finish though.. Plain white/black and gloss, and a more subtle grille.
Somewhat OffT question:
If Im running AV receiver + stereo amp (with AV-in) connected to pre-out of the AV receiver (fronts connected to to the stereo amp) , how would one connect the SB2000 to be able to use it for both movies (AV) and music (2ch)?
AV receiver to LFE and stereo amp to...?!
fayeanddavid
Has anyone purchased this that previously had an XXLS400 or Mono?
Good ask, as that's a question I would ask
The SB 2000 seems to dig as deep as the Mono (?? I think I read) but would be more "agile", question; would it be subjectively "better" like a bigger better xxls 400??
Would appreciate a comparison comment, thanks
fayeanddavid
Gotta let us all know impressions
Quick get it unboxed and plumbed in!!
Podcast: The Best TVs and Projectors of 2020, plus AV, TV Show & Movie News & Reviews
Latest News
What's new on Sky and NOW TV UK for December 2020
  • By Andy Bassett
  • Published
What's new on Netflix UK for December 2020
  • By Andy Bassett
  • Published
Warner Bros 2021 movies coming to HBO Max and cinemas simultaneously
  • By Andy Bassett
  • Published
What's new on Disney+ UK for December 2020
  • By Andy Bassett
  • Published
4K Streaming impacts carbon emissions says Royal Society
  • By Andy Bassett
  • Published
