JL12W7
I have a dilemma. I need 6 Atmos speakers so I ahve gone along with 4 X KEF R8A front & rear heights then add two ceiling speakers to give me 7.2.6. I checked on Dolby web site and this situation works as far as they explain with pictorials. I had opted to not cut holes in the ceiling and prefer to surface ceiling mount speakers instead as I found out it is not a very safe practice for angled down firing speakers and is not advised so the only available option is the SVS prime elevation as it lends itself for multiple placement, wall or ceiling.
My only concern with the SVS PRIME ELEVATION is first the price is extortionate for a what the speakers is very small with a 4.5’’ mid range I mean £549 is ridiculous price it is a money grab for sure & in my room that will not be very loud speaker compared to the rest of my setup and that is putting me of buying it as it seems an awful outlay for what is essentially a very small tiny speaker on the other hand the Monitor Audio C380-FX in ceiling speaker is actually £100 cheaper and has an 8’’ woofer means better sound, right? More base and a far greater absorption of sound which would reflect the rest of the system.
Question is does anyone on this forum have these SVS speakers who can give a thumbs up are they worth the money and are they good enough for the application I intend to use them, no sense in me phoning the shop to ask as they will only tell me what I want to hear so I need an unbiased and truthful reply.
I don’t really want to buy the in ceiling speakers as if I move I might end up with speakers I could never use again and to sell them would be a total waste of money as I would never recoup my original outlay on the Monitor Audio C380-FX. I could install them and just cut the holes into the ceiling no problems and would be an easier job where I am now, I mean I would hate to cut a massive hole into my ceiling if at all possible I would prefer surface mounted or are there any other options out there.
The SVS Prime Elevation are ripping the price as they know an understand there are people like me and that is why the price on these tiny teeny speakers are ridiculously expensive, if no other option is available I may just go with the in ceiling speaker as the SVS Prime Elevation I don’t think could compare to the in ceiling speaker if I am being truthfully honest. Not unless it performs and is up to par with a big system as I have never heard them myself it is hard to gauge and without knowing what they are capable of maybe I am wrong so I need to be educated and have someone explain they are worth the money and that is why they are so expensive is because they are fantastic loud crisp sound that can keep up with any system no matter how big the other speakers are as the SVS Prime elevation will integrate really well you see that is what I don’t know and that is what I would like to find out So if anyone can give advice would be appreciated.
Thank you
Thank you
