SVS performance (cylinders vs boxes)
Discussion in 'Subwoofers' started by UrbanT, Nov 27, 2004.
  1. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    Simple question :)
    In real terms, what would be the difference in performance between my 20-39+, and a PB12 Plus/2 (or Ultra 2)?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Higher SPL and lower distortion thus increasing quality of sound. The PB-12 Plus/2 is one of the best real world subs around but according to the Secrets of Home Theater review the PB-12 Ultra/2 is reference quality.
    Are you thinking of treating yourself to a 38th Birthday present today - many happy returns by the way
  3. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    Nothing gets past you does it Ian :thumbsup:
    Part birthday present, and part upgrade. I have changed my front speakers, and would prefer a box sub which will now fit in my room better.
    I would prefer it to be an upgrade rather than a sideways move, so want to make sure I buy the right one. Without being able to see them, I need some advice :hiya:
  4. recruit
    recruit
    Urban T - I love you're Home Cinema it looks sooo Cool :cool:
    But the SVS box subs are huge would it go at the Front or Back?
    John
  5. rags
    rags
    Apr 13, 2003
    4,087
    London
    +304
    Urban T - what new speakers did you go for ?
  6. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    Signature 805's. :)
  7. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    Thanks John :smashin:
    Have you seen the SVS cylinder in my room, it makes a Nautilus 804 look small. The 'problem' is 3 fold. Firstly, I want the sub away from the front to allow some movement for the 805's. You can see in the pictures on my site that there is no room to move anything.
    Secondly, and of no real importance, but the 805's are beautiful speakers, totally dwarved by the cylinder.
    Thirdly, and more important, is that I want a sub closer to the seating position, so you get more of the rumble through the chairs. I tried to put the 20-39 along the sidewall, but it always interfered with the 804's. With standmounters now, I could accomodate a box on the left hand side (and would make a useful table to put the pizza's/popcorn etc :laugh: )
    Chris
  8. rags
    rags
    Apr 13, 2003
    4,087
    London
    +304
    Wow. Good one.
    The Pb2+ and Ultra will defintately be better than your cylinder. Problem is I dont think you will be able to accomodate one between your speakers - it will have to go on the side I think. Great HC pics buy the way.
  9. recruit
    recruit
    The 805's are beautiful speakers and the sound is even better the SVS's do make excellent subs and if it were my money and could accomadate one i would definitly go for the PB12 Ultra/2 it would make for an awsome setup loads of deep deep BASS!!!!
    John :)
  10. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    The idea of getting the sub would be to stick it against the side wall to bring it closer to the seating position (see my post above).
    There seems to be a huge gap in cost between the Ultra 2 and the Plus 2, as well as the plus having a slightly smaller cabinet, so that may end up being the choice. Its a tiny room (8ft x 15ft approx), so the Ultra may just be a little overkill?
    Does anyone have/heard either of these yet?
  11. Daneel
    Daneel
    Dec 5, 2002
    2,822
    68
    London
    +26
    Plus 2 in wood finish would be my choice. Yes, the ultra 2 is overkill, but then so is the plus 2. I'm sure smurfin will disagree :)
    Performance wise though, in that room, going from a cyl + to box + 2, I doubt there would be any difference in sound at all.
  12. rOAdeh
    rOAdeh
    Jan 24, 2003
    602
    Winchester
    +5
    lol... sounds like you may want to buy my dd15 off me when i realise that its completely ott for me chris :)
    on topic i'd have to agree that the pb12 plus 2 would be the best price/performance ratio for you if are looking to upgrade
  13. Nimby
    Nimby
    Jan 27, 2004
    9,201
    The Danish Bacon Factory
    +669
    I'm pretty sure you would notice an improvement in sound quality if your speakers could breathe more easily. My 16-46 completely modifed the sound of my Mission 753Fs. Simply because it was sitting next to the left one. The left speaker being nearer the corner of my 30 feet long room. Moving it to just inside the right speaker made a huge difference in the measured frequency response and tightened the bass dramatically.
    Now you've moved on to standmount speakers. (probably an excellent idea given the dimensions of your cinema) I'd try laying your cylinder on its side on the floor. Just as an experiment to give more air around your speakers. I think you'll notice an immediate difference in bass quality. The cylinders work just as well on their sides according to Tom SVS. You could even use it as a foot rest while perched in your gorgeous chairs. But what a way to treat an SVS! :devil:
    Nimby
  14. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    Are you winding me up re laying it on its side? :)
    If its genuine, I'll give it a go and see what happens. Where did you read about Toms comments?
    Chris
  15. recruit
    recruit
    It'll be like walking the Log :D
    John :)
  16. Nimby
    Nimby
    Jan 27, 2004
    9,201
    +669
    It was discussed in a private communication with Tom V prior to purchase of my own (potential) foot rest.
    The idea being to hide the cylinder behind the TV and speakers where there was plenty of room in my attic listening room.
    In the event it wasn't necessary. My wife didn't object quite as strongly as anticipated to the 16-46 when it arrived. :rolleyes:
    Nimby
  17. Smurfin
    Smurfin
    Aug 13, 2002
    20,797
    +4,161
    You'll still notice it if you play movies around the -5db mark (imho).
  18. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    I tried lying the log on its side, it looked as bad as I expected :laugh:
    I also measured up the PB12/2, its gonna be a monster for the room. Decisions, decisions......
  19. rags
    rags
    Apr 13, 2003
    4,087
    London
    +304
    Urban T - just get a B&W ASW850 mate. Looks and sounds great :smoke: .
  20. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    I'd be happy to, just don't have the cash to get there :)
  21. recruit
    recruit
    Urban T - for the money you will get back on you're SVS and add the rest it wouldn't be much more to buy a ASW850.
    When i sold my SVS i more or less got the same money back as what i paid for it!!
    John
  22. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    Lets consider that.
    SVS = +/- £500 - £2000 B&W = £1500 shortfall = much much more :)
  23. recruit
    recruit
    Yeah but you was going to buy another SVS how much was that going to cost?
    John
  24. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    I calculated a total cost of a PB12/2 to be around £1000/£1200, which is where my ideal limit sits.
  25. recruit
    recruit
    Ok, Maths was never my strong point! :rolleyes:
    John :)
  26. rags
    rags
    Apr 13, 2003
    4,087
    London
    +304
    Chris - If you want it to look good next to your Sigs then the wood finish SVS is the one to go for. The black looks like a monster - before the SVS crew slaps me down Id like to point out that it performs very well regardless :rolleyes:
  27. rags
    rags
    Apr 13, 2003
    4,087
    London
    +304
    Urban T - good decision imho to go for the ASW850. You will never look back :thumbsup:
  28. Smurfin
    Smurfin
    Aug 13, 2002
    20,797
    +4,161
    You know it :D I'll never forget playing Cafe Del Mar in my old listening room at -0db in stereo, with the PB-2 Plus. Made my jaw hit the floor :D (still looked like the back end of a bus but it doesn't matter in a dedicated room now, does it?:) )
  29. smallangryboy
    smallangryboy
    May 5, 2003
    1,877
    +59
    The SVS 25-31 PC+ may be under threat, as my better half has plans of doubling the sub up as a piece of furniture, I know criminal ! That leads me to look at the SVS boxes, and I wondered what in their range would be the equivalent of the 25-31 PC+ ?
