svs-pc ultra
Discussion in 'Subwoofers' started by Andywilliams, Dec 31, 2003.
  1. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Hi folks
    Check svs news out on there website they are now releasing the pc-tube series with the ultra driver and parametric equalizer and all for $1100 another feather in svs cap.
    Is there a cure for upgraditis.
    Cheers Gonzo.:D
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    According to my calculations it should arrive on your doorstep for a little over £900 with all taxes paid and that must make it the best value supersub around.
    Who's going to be the first then ;)
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Hi Ian
    Ive emailed TV to see if we could fit the ultra driver in our subs and what the benefits would be if any,Also cost for buying and shipping the drivers to the uk.
    Cheers Gonzo.
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
  5. jag77
    jag77
    I tried to explore the possibility of fitting a ultra driver in a PC+ sub enclosure.
    but reading on other like-minded freak's experience, it seemed that the ultra driver can't fit in a PC+ enclosure....... something to do with height/fit/port tubes......etc.
  6. Toekiller
    Toekiller
    Bog off.
    You bastards already got me to buy one. I don't need another!
  7. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    :D You know you want another one, twice the fun!:smashin:
