David/Hoppaz
Thanks for your responses.
I would have thought you would get distortion at high volumes only? I set my onkyo level to zero and the sunfire volume knob to about one fifth only which is fairly low.
With the sunfires I can really feel the sofa shake and I can feel the bass on my chest but with the pb13 I just don't get the same effect.
I will tweak the settings further on the pb13. I must be doing something wrong otherwise im sure so many people wouldn't have raved about the pb13.
saguk1234 said:I think the PC13/PB13 don't sound good when fully sealed. Its probably best to use the 15hz tune with one port bunged. Or try it unbunged.
aandpwoodley said:I think the problem is the Ultras don't offer as much mid range punch as the sunfires.
If you listen to some music which goes to 20hz or below, this is where your really here the ultra come into its own.
Thanks to be honest I don't really listen to music its mainly for movies!
I note you sold yours recently and purchased the dd18±. How do you find the dd18?
aandpwoodley said:I love my DD18+, easily the best part of my system, very punchy & how's loads & loads of low end grunt.
For the size of the cabinet it's a remarkable piece of engineering
i_raz said:I guess It will take some time to adjust to the pb13. I was thinking about selling it on but I think I may just keep it now. It's just that 2 sunfires really energise the room and really shake the sofa. I can't get the same effect from the pb13.
MI55ION said:This is most likely a room null or setup issue.
Have you tried different ports? REW sweeps? EQ? Sub location? Gain?
Edit btw, is that a MA pl series centre sitting on the floor? Does it work well with the non pl mains?
