SVS PB12-ISDcuts out at low volumes
Discussion in 'Subwoofers' started by mariob33, Nov 28, 2004.
  1. mariob33
    mariob33
    Nov 28, 2004
    3
    I have a PB12-ISD hooked up to a yamaha RXV2400 and when i turn the volume to a lower level for a period of time the sub seems to fall asleep and it then takes a heavy hitting bass kick to wake it up or if i turn the volume way up. Any comments suggestions on how to fix this?
  2. recruit
    recruit
    It sounds like the LFE Level is too Low and needs to be turned up alittle bit more as the SVS keeps on shutting down, or else turn the Auto Function OFF on the Sub and just leave it on all the Time!!!
    John
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    Turn the Auto function off. This feature of American subs is more trouble than it's worth but at least on SVS you have the alternative to disable it. I did and never have any problems at all
  4. mariob33
    mariob33
    Nov 28, 2004
    3
    i will try your recommendations.. im assuming its just the switc on the back that says auto? Whats a decent level for lfe mine is set to 0 db currently
  5. recruit
    recruit
    That sounds about right i would just turn off the Auto function!!!
    John
  6. General Skanky
    General Skanky
    Jul 28, 2000
    4,208
    71
    +43
    Does this sub have a single input for the LFE?
    I ask as on my sub I have L and R inputs and split the LFE lead to them both. I believe it makes the sub more sensitive (?) and I have no problems at all with the Auto setting.
  7. recruit
    recruit
    Yes when you plug the 2 in L/R then voltage increases and so does the sensitivity and the sub wakes up quicker the only problem is that it also increases the level which I found annoying when calibrateing.
    John
  8. General Skanky
    General Skanky
    Jul 28, 2000
    4,208
    71
    +43
    I didn't know that.
    Does it throw the calibration off that much?
  9. recruit
    recruit
    I found that it did by about 3-4db!
    I think it's best just to leave the Auto function off
    John
  10. General Skanky
    General Skanky
    Jul 28, 2000
    4,208
    71
    +43
    I wish you hadn't said that. Means I'll have to go and recheck it all again. :)
  11. Nimby
    Nimby
    Jan 27, 2004
    9,201
    The Danish Bacon Factory
    +670
    You only have to calibrate once.
    You take the increased output into account while you're calibrating.
    The increased output simply means you turn down the sub slightly to match.
    BTW: Twinning the inputs doesn't affect peak output. So the sub doesn't suddenly become an Ultra thanks to a couple of quid's worth of cables.
    Nimby
  12. Andreas
    Andreas
    Why don't you try bumping up the gain on the reciever for the subwoofer channel, at the same time lowering the gain on the subwoofer amp. That would give the sub a higher signal to keep it awake durring the quiet times.
    Andreas
