Svs Pb10 Isd - What Next.....?
Discussion in 'Subwoofers' started by NICMAC, May 8, 2007.
  1. NICMAC
    NICMAC
    Mar 11, 2007
    426
    +17
    Hello everybody,
    I have a pb10 which i have been perfectly happy with but it is now time to upgrade to something better. The PB 12 NSD is probably the largest size i would like to accomadate in my living room, i have also considered the SB12 PLUS, my thinking is from reading many posts that i would get better quality base but saccrifice output a little? Is this the same with the smaller Velodyne series also?
    I have also looked at the many M&K subs and as some of these can be had cheeper now they look better value.
    The speakers i have that the sub will be partnering are M&K 850's (fantastic by the way) i know that they can sound even better with a better quality sub, my budget is around the 5 - 600 mark, guess i could stretch a little more for the right sub ;)
    Appreciate any suggestions for my setup :)
  2. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    The obvious step up is the SVS PB 12-Plus which you should find will go louder, deeper and tighter but if you want to wait a few months until the cylinders are re-introduced to the UK the 20-39 PC Plus will be a good upgrade.
    I ran a PB-10 and 20-39 PC Plus side by side for a while and the difference was worth the extra cost
  3. NICMAC
    NICMAC
    Mar 11, 2007
    426
    +17
    Thanks very much Ian,
    Not knowing much about the cylindars, would the 20 - 39 PC be on par with the PB12 PLUS ie same quality and output in a different shape?
  4. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    The cylinder and it's equivalent box shaped sub use the same components and according to SVS themselves sound similar.
  5. NICMAC
    NICMAC
    Mar 11, 2007
    426
    +17
    Thanks again
    Hopefully i should get some more opinions on other brands also
  6. The Gooner
    The Gooner
    Dec 5, 2004
    1,390
    48
    NE Lincs
    +44
    I am interested i nthe Velos so any info would be good. Looking at the SVSPB12+ also but after having a qauke it isnt easy getting away with the extra 4".
    The Velo on the other hand is same size as quake.
