Shapely
SVS are known for their active subwoofers but in this day and age you have to diversify if you want to stay alive so the news they're coming out with a range of speakers comes as no real surprise.
Led by designer Mark Mason, the new Ultra speaker design feature a range of floor and stand speakers, centre channel and surround models.
The Ultra Tower is a flagship 3.5-way tower loudspeaker with a 1-inch aluminium dome tweeter, dual 6.5" glass-fibre midrange drivers, 3.5" flared rear-firing port and dual horizontally-opposed 8" woofers. It stands an imposing 114cm tall and features an unusual 'upswept trapezoidal' shape in piano gloss black and real black oak veneer finishes
SVS says its non-parallel cabinet panels reduce frequency response colouration, while the wedge-shaped front baffle and flush-mounted drivers reduce edge diffraction and improve on-axis high frequency response. Grille design and cabinet bracing are FEA-optimised to maximise acoustic transparency. Each cabinet employs two separate sealed midrange enclosures; midrange/tweeter baffles are 1" thick and the woofer baffles are 1.5" thick.
The Ultra Bookshelf speakers were developed in parallel with the tower, and is a two-way reference monitor system in another trapezoidal cabinet, finished in a choice of premium-grade piano gloss black and real black oak veneer. The system offers Ultra range engineering and components scaled for a bookshelf design, namely the commonly applied 1 Ultra tweeter, 6.5 glass-fibre woofer and SoundMatch crossover, together with a 1.7 flared reflex port, all housed in a cabinet, which is complete with FEA-optimised bracing and grilles, a wedge-shaped front baffle and flush-mounted drivers.
The Ultra Multichannel speakers are acoustically matched and come named as centre and surround speakers; the centre being a three-way design featuring the 1" dome tweeter, 4" vertically-aligned glass-fibre midrange driver and dual 6.5" woofers.
The wedge-shaped wall-hugging surround features sets of the 1 Ultra tweeter and a 5.5 glass-fibre woofer flush-mounted on 45 degree baffles. For system flexibility it offers three surround modes: bipole, in which both sets of drivers are in phase; dipole mode when both sets of drivers out of phase, and duet, which involves each set of drivers receiving a discrete signal.
SVS Ultra speakers, typical retail price inc VAT:
Tower £2200.00 pr
Bookshelf £1099.00 pr
Center £749.00
Surround £1299.00 pr
Tower £2200.00 pr
Center £749.00
