SVS Frequency Response
Discussion in 'Subwoofers' started by gkl68, Apr 18, 2005.
  1. gkl68
    gkl68
    I was looking at the frequency responses for the SVS subwoofers on their webpage and notice that some of the cheaper models actually have better responses than the pricier ones. For example, I compared the PB12-Plus/2 vs. the PB12-Ultra/2 and the Plus seems to have a higher output. Doesn't that mean the cheaper Plus model performs better?
  2. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    No.
    The graphs are to demonstrate extension and eveness, not volume.
  3. gkl68
    gkl68
    so at around the same price, would you recommend me buying the PB12-Plus/2 or the PB12-Ultra? Thanks in advance.
  4. the thing wnn
    the thing wnn
    Sep 1, 2002
    3,967
    Brecon Beacons
    +763
    i faced a similar dilemma myself, although i was also restricted by size, the Plus/2 is a fair bit bigger than the Ultra.
    I think it comes down to how much oomph you want. At lower volumes, the Ultra may sound a little better as its a superior driver, but if you crank it, the Plus/2 will have more headroom.
    I went for an Ultra, but as i said, i was restricted by a size issue. I think i'd have gone for an Ultra anyway, as i don't think i could ever crank it to the level needed to notice the extra driver!
  5. gkl68
    gkl68
    Makes a lot of sense. I think I'll just go for the extra headroom since the cabinet for the Ultra is already massive.. an extra 4" for the Plus/2 isn't a big deal to me. Thanks!
