SVS arrival!!
Discussion in 'Subwoofers' started by t-force, May 22, 2004.
  1. t-force
    t-force
    May 2, 2001
    1,872
    Southampton, UK
    +152
    At long last, courtesy of Jase, I have now got my 20-39+, and it's sat looking menacing in the corner of my room.
    I need to change the power cable however, and I was wondering:
    would I need a completely new cable, or could I just chop the plug off the end, and put a british plug on instead? If I do do that, does anyone know which flex colour is which? I've got a white cable and a black cable, but don't know which is live and which is neutral, and for obvious reasons, I don't really want to get them the wrong way round!
    Cheers,
    Toby
  2. Daneel
    Daneel
    Dec 5, 2002
    2,856
    68
    London
    +8
    I chopped off the end of my Parasound power cable without any problems.
    How to wire a plug
  3. t-force
    t-force
    May 2, 2001
    1,872
    Southampton, UK
    +152
    I know that that is the British standard, but this is a US cable, and the flex colours are Black + White, not Brown + Blue, so I'm in the dark as to which is which.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    I binned the supplied cable and just used one that I had lying around that came off a printer. I keep meaning to upgrade it and one day no doubt I'll get around to it.
  5. GaryG
    GaryG
    Nov 20, 2002
    754
    Shropshire
  6. Stellavision
    Stellavision
    Apr 7, 2003
    2,472
    Portsmouth, UK
    +128
    A pc psu cable from Maplins or similar should surfice. Thats what I used on my 25-31 pci.
  7. Nimby
    Nimby
    Jan 27, 2004
    9,206
    The Danish Bacon Factory
    +671
    I'm not a mains cable freak but I replaced the standard 2 x 1mm^2 SVS cable with 2 x 1.5mm^2. Finding a removable IEC female plug to fit the sub wasn't easy as most plugs are moulded on. A DIY superstore had a short lead with removable plugs. So I replaced the fitted cable with 6 metres of rubber sheathed cable for flexibility to help me reach the subwoofer. I believe heavier cable helps heavy transients particularly when a much longer cable is required. The SVS subs are not earthed so only two-core cable is required.
    Nimby
  8. Daneel
    Daneel
    Dec 5, 2002
    2,856
    68
    London
    +8
    Sorry about that, I didn't read your post properly.
