SVS 20-39PC+ popped its fuse! Incorrect antimode 8033 setting.
chrisgeary
Only time in 6 years thats happened. I think whats gone wrong is I bought an anti-mode 8033 and mistakenly used the Lift 25 mode. That'll teach me to not use REW to verify the frequency response and I would have realised that with the 20-39, I don't need Lift anything! I thought I needed it for a house curve, but I really don't think I do.
I was listening to some particularly bass heavy drum and bass and a lf transient caused the driver to hits its end stops and the fuse went.
New fuse installed, Lift 25 off and all is well again :)
hoppaz
Wow strange one, what was your sub "tuned" too?
chrisgeary
16hz
Bumping an old post, but
Just turned my svs on, and the internal fuse went pop.
How do i replace it???
Is it soldered in??
Found the glass fuse, doesnt look popped but cant check till tomoz, hope it is popped as the fuse on the cable is fine
Similar threads
