SVP350 bulb problem
Discussion in 'Projectors, Screens & Video Processors' started by minus, Nov 28, 2004.
  1. minus
    minus
    I don’t know much about projectors as this is the first 1 got my hands on. It's a SIM2 SVP350 PLUS PJ. When I turn it on, everything seems to work... but the Green centre bulb looks "fuzzy" when I look directly into the bulb I can see a lot of dust/dirt at the back of it, the other 2 bulbs look fine. Does this mean that the bulb needs to be replaced or is there some way to clean it?
    Ged
  2. BenC
    BenC
    Oct 15, 2002
    376
    London
    +6
    1) Unplug from the mains!
    2) Remove the lense in front of the green tube (make a note of which small metal sims are behind each screw) and clean carefully. You can do the other lenses whilst you're there if they need it. Whilst the lenses are off check the tubes for burn. See here for more info: http://www.crtcinema.com/crtratings.html
    3) Screw lenses back into place. Re-focus all three lenses. Basic instructions are in the manual.
    The tubes should last around 10,000 hours if the projector has been setup correctly. If, however, the tubes been overdriven they can last considerably less. It's worth checking the working time of your projector. Off the top of my head I can't remember which menu this is in, but one of the other guys here will know.
  3. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,743
    Cheshire
    +107
    It could be dirt as BenC suggests, but there's a dust seal between the lenses and tubes of a 350 which usually stops this sort of build up. Curious that one lens is affected and not all three.
    Whip the lenses off and have a look anyway. BTW, I'm sure you know not to use chemicals or abrasive cleaning products on the lenses or tubes :hiya:
    Another possible cause is the Electronic Focus adjustment is seriously out of whack.
    Regards
  4. minus
    minus
    Ok, thanks you both for the advice will have a look at it today, and let you know how I get on.
    Ged
  5. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,438
    48
    +64
    I presume you focused it correctly?
  6. Boy Lex
    Boy Lex
    I've had exactly the same problem with one I just got from this guy I would highly recommend you avoid from eccles (eBay). I say that because I gave him a good price for a 350 because as he said, 'I knew what I would be getting'. Hmmm. Anyway he's ignoring me now because he's got his money I guess.
    Anyway. I found out that the problem was fungus... and boy was it fungus! It's a bit of a job but you need to drain the coolant from in front of the tube, pull the glass of the front of the tube, then scrape the fungus off, clean it, reseal it, filter the coolant and return it to its home.
    I found full details on http://www.eboyztoyz.com/index.php?ncat=145 which seems pretty comprehensive.
    I've just put the coolant back in and have lost about a centimeter in the process. I've read all sorts of suggestions for topping it up like baby oil, anti-freeze, deionised water, etc... Not really sure what to topit up with tho. Any ideas?
    Looking forward to getting it going without the fungus (it was like grease all over a frying pan after the biggest fry-up you can imagine!)
