Svideo out?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by paiger, Feb 18, 2002.
  1. paiger
    paiger
    My Sony box outputs RGB but not Svideo. If I want to hook it up to my projector which has Svid and composite, is there any way of converting RGB to svid? I can run everything through my amp but only in composite for the moment. Any ideas?
  2. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    Try...
    www.rgbtosvideo.com
    They sell the converter you are after.
    btw, I have one too.
    HTH
  3. paiger
    paiger
    Cheers Kevo, looks like just what I need. Got a good review in What TV as well. Thanks again.
    S
