I'm having some problems with connecting up my pc to my tv.
I have tried various ways of connecting it, such as svideo, composit and scart, and I've only managed to get a black and white picture on it using scart.
The setup I have is:
ATI Radeon 9800 Pro with svideo out and vga out (15pin d-sub)
Panasonic TX-21S1T that has
1 scart connector
red, white and yellow comopiste connectors on the front
Manual is available here:http://www.panasonic.co.uk/customer-Support/download-centre.asp?did=128092&fmt=pdf
I got the black and white picture by using a 4 pin svideo to scart connector from maplins:
http://www.maplin.co.uk/module.aspx?TabID=1&criteria=svideo to scart&ModuleNo=35910&doy=27m2
and I've just bought this:
http://www.maplin.co.uk/Module.aspx?ModuleNo=35904&criteria=svideo to scart&doy=27m2
to use with a 7 pin ati radeon svideo to comopiste adapter. But I get no picture on the tv.
The results so far:
4 pin Svideo to Scart (from maplins quoted above) = Black and white picture
7 pin svideo to composite adapter to composite in on front of tv = no picture
7 pin svideo to composite adapter to composite on scart adapter = no picture
4 pin svideo to svideo on scart adapter = no picture
I have tried the latest Catalyst drivers 6.2, as well as older ones (4.8, 5.2) but still no picture.
When I remove the composite connector from the front connection on the tv, the screen flickers, so there is power going to it, but it must be in a format that it doesn't understand.
I am now looking to get one of these: http://www.maplin.co.uk/Search.aspx?criteria=averkey&doy=27m2&source=15
as it uses the vga output on my graphics card.
Can anyone help me with this please? Ideally I don't want to spend £40 on the averkey thing, and I've now got cables and scart adapters everywhere!!
Thanks, Nathan
1 scart connector
The results so far:
Thanks, Nathan
