SVIDEO connection
Discussion in 'Cables & Switches' started by tblair, Jul 5, 2004.
  1. tblair
    tblair
    I have an old Hitachi RP TV (it just won't die). I have connected directly to the first video feed on my TV with a SVIDEO cable from the SVIDEO output on my DVD player. I also have a regular RCA feed to my receiver from the DVD player which in turn feeds the TV with RCA on the second video on the TV. So I can switch between one and two and thus see the difference between RCA and SVIDEO.
    I don't see any difference. There is a reference in the DVD manual to using both the RCA and SVIDEO connection at the same time.
    Is that necessary to realize better quality for the SVIDEO connection?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    An s-video connection should be miles better than the very basic composite connection available via the phono (RCA) outputs so I wonder if you have set it up correctly.
    In the UK most DVD players won't default to outputting s-video but have to have the default changed in the setup menu and I wonder if that is what is wrong.
