Svideo cable recommendation?
Discussion in 'Cables & Switches' started by wyerd, Jul 17, 2003.
  1. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    I recently ordered an Ixos XHV403 (124) 3m Svideo to Svideo cable to replace the cheap one I was using from my Grundig GDS3000 STB to my capture card on my PC. I plugged it in and I am very disappointed with the result. It’s picking up interference even though it’s meant to be shielded etc – it’s so bad I’ve plugged the cheapo cable back in. Can anyone recommend a good quality cable that doesn’t suffer from interference as the Ixos?
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,004
    48
    Reading, Berkshire
    +54
    What capture card are you using? It could be noise from your PC being picked up by your capture card, rather than by your new cable.
  3. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Yep - you're right. I did my own fault analyisis - swapped the PowerColor 9200 VIVO with a Nvidia Geforce from another PC and a LifeView 2000 capture card I used for testing before I built the HCPC. Fantastic picture! Looks like these VIVO cards are crap...... unless anyone can recommend one as I've now used up my only PCI slot on the Shuttle - main reason for buying the VIVO card in the first place!
