svideo aspect ratio problem
Discussion in 'Cables & Switches' started by tigermad, Dec 30, 2004.
  1. tigermad
    tigermad
    Jan 2, 2004
    4,878
    Bedfordshire
    +274
    I am running my new av system via svideo to my pioneer plasma. Since I have done this the aspect does not swap to the correct ratio (it stays the same all the time). Do I need a special Svideo cable in order to acheive this?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    AFAIK you can't send the apsect ratio switch signal (pin 8 I think on a scart lead) via S-Video. Therefore its DIY or switch connection type.
    Mark.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    This is a common problem if you have an AV amp, because most AV amps do not use scart connections. I switch my TV manually when necessary.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,754
    Somewhere in South Yorkshire
    +4,908
    Yes, do it manually. Indeed, many of the problems people experience here with aspect ratios come from automatic processes not doing it exactly right.
