SVHS on SONY 750 or 760?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by smallman28, May 5, 2002.
  1. smallman28
    smallman28
    Does anyone know if either the Sony VTX750 or 760 have a SVHS connection?
    My current Grundig does and I want to change to a Sony but not loose the SVHS if possible.
  2. paiger
    paiger
    The 760 has does not have Svid, only RGB. You can get a converter but it will set you back £70 odd. It's a good box though and very slim.
    Steve
