SVHS Laserdisc picture
Discussion in 'Projectors, Screens & Video Processors' started by mattcl, Mar 26, 2001.
  1. mattcl
    mattcl
    I have a Sanyo PLV30 projector, which is hooked up to my DVD player via the component video input. No problems there - picture is great.
    However, I also have a Pioneer 915 Laserdisc player hooked up through the SVHS input. There is a definite reduction in picture quality, as you would expect from the SVHS input. I don't think my setup is doing justice to the laserdiscs.
    Would it be worth buying a seperate Composite to Component video convertor to sit between my laserdisc and projector, so that I could use the component input for both the laserdisc and the DVD?
    Matt.
  2. titan
    titan
    Actually i think youll find that laserdisks arent doing justice to your setup.
    on my pionneer cld 98 and sony 10ht the picture is way poorer than even dvd runnind svhs.
    laserdiscs just have too low a resolution and introduce too much video noise tyo look good blown up too such a size and too think not too long ago laserdisks werer the best. how times change
  3. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    DVDs are recorded in digital component, laser discs are recorded in analogue composite. There is a big difference in quality between the two, this is why you see such a reduction in resolution.
    Regards
    Chris Frost
    Regional Sales Manager-N.England & Scotland
    Owl Video Systems Ltd
    www.owl-video.co.uk
