SVHS cables for DC
Discussion in 'Nintendo Forums' started by a1bert, Mar 7, 2003.
  1. a1bert
    a1bert
  2. phenom2003
    phenom2003
    do you mean just for the DC, or do you want a spider one.
  3. 2manyconsoles
    2manyconsoles
    Aug 21, 2002
    142
    16
    Chester
    I think amazon have a multi format one - its worth mentioning these S-video cables are just composite cables - not all four pins are connected - there is one signal that splits to the four pins and not four seperate signals as you would get from a proper cable - I discovered this when my DC s-video cable broke.
  4. a1bert
    a1bert
    Thanks for the info.
    I was looking for a spider cable. I have all the consoles except Xbox, and wanted a single cable.
    I have scart/RGB cables....but the TV i want to connect to is a 50" rear projection Toshiba....pain to keep moving in and out to get to sockets on back.
    wanted to use SVHS or phonos on front!
    Cheers anyway.
