SVGA CABLES for a rgb to plasma vga box
D
dfh28
Can anyone recommend suppliers for these cables
I will be conecting a panasonic TH50PHW5B and will be needing a good quality 5m cable.
Also can anyone tell me what ends have to be on the cable.
Many Thanks
symanski
15-pin High Density male connectors.
Ensure that the cables are built from high quality co-ax cable, with an impedance of 75 ohms. 5m is not a problem. What's important is that you're now using the right signal, then you start to look at cables for smaller improvements.
All the best,
Dr John Sim.
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
